Macbook Pro Touch Bar Support
Re: Macbook Pro Touch Bar Support
What would you like to see on the Touch Bar?
VJsynC
Post by VJsynC »
Anything... a few examples:
- clip controls to the selected layer
- a shortcut to the advanced display options to enable os disable slices without actually going to advanced display e do that manually
- thumbnail horizontal list of clips in the selected deck
- or probably the most annoying thing of them all... a better way to display the deck list horizontally with full deck name length to avoid this:
..or none of the above and let the user customize what they want to see in the touch bar... in the mapping options you could have like:
"Edit Application Touch Bar"
or
"Edit Composition touch bar"
VJsynC
Post by VJsynC »
oh.. and... by the way...
if you are really considering adding support to the touch bar, and since it's basically an WatchOS (IOS) based system why not go like super crazy and do an app for iOS (to use on a Ipad) that could work as an extension to the resolume software system?
an app that could for instance help remotely do the mapping in the advanced output without us having to stay in front of the machine (PC or mac) for us being able to go physically closer to the projection area or those led panels to sort out those little details and corners areas that are just to small to see where the computer is located!
the app could also work like an a extension of a selected deck to show more thumbnails on the fly.. or could even work as a better way do media menage our content inside resolume!
but yeah... this is like a long term suggestion if you are considering entering in IOS world... starting with the touch bar support could be a nice stating point thought! ;)
cvanhoose
Post by cvanhoose »
I would love to see a color picker, for the hue/saturation effects + colorize.
I have ordered one if you need a tester ;)
frankfunk
Post by frankfunk »
Has Touch Bar support been abandoned?
frankfunk wrote: Sat Feb 08, 2020 00:05 Has Touch Bar support been abandoned?
No, it has been implemented in Resolume 6 ;)
microfx
Post by microfx »
Zoltán wrote: Sat Feb 08, 2020 09:02
I can't find anything in the manual .. I only see Master Slider, Bypass and Link 1 slider ... how can I make my own preset?
