Spout
Spout
Does anyone know of a free program that will take screen capture to spout? I have the spoutsender2.dll and am just looking for a program that will capture a specific window (or app), or entire window and send it to spout, so I can have that as an input in my comp.
I got this working with syphon and NDI on osx, just trying to find the simplest solution for windows.
mister mishka
Re: Spout
Post by mister mishka »
If I remember right you should be able to screen capture with VLC, and now you can use VLC as a source for spout. You have to download a file first, but if you join the "VJ Union Global" on facebook and search "VLC", you should get a post from Grigori Vdmo Kstati who provides the file of what to download and how to get VLC working in Resolume via Spout. 8-)
Re: Spout
You can also try using vMIX NDI screen capture programs for both MAC and PC: http://www.vmix.com/software/download.aspx
Re: Spout
Thanks again Oaktown! HAt's off to you for always having a great answer! :)
