live video source size issues
hiten
Post by hiten »
When i take magewell or aja live input in resolume v.5.1.2 via usb 3.0, i apply the size to input video, after i switch the deck the video loose its size and come when to original when i switch back to that deck
Re: live video source size issues
Unlike a clip, a live input has no width and height of its own. The width and height change depending on the resolution that you capture with it.
So when a live input gets (re-)loaded, we have to check what resolution it is in order to show the captured image at the correct size. This overrides whatever changes you have made to the width and height.
The best way to resize a live input is to leave the width and height as they are, and just use scale instead.
Might dedicate a layer to this input and modify the layer properties as well??
hiten
Post by hiten »
thanks for the replies.
