Send MIDI CC recorded in Ableton Live to Resolume?
Daisuk
Post by Daisuk »
I've recorded a bunch of MIDI CC clips in Ableton Live that I want to route into Resolume somehow (to mess with layers and effects and what have you) - but how would I go about doing this?
Is this at all possible?
Any help on the subject would be much appreciated. :)
Daisuk
Re: Send MIDI CC recorded in Ableton Live to Resolume?
Post by Daisuk »
Having searched a bit around I guess it should be possible with some creative MIDI routing. I'll try to see if Bome can do it. :)
On mac just add a port to the IAC device in Midi studio, and set it up as output in ableton and input in Resolume.
On PC get loopMidi from here: https://www.tobias-erichsen.de/software/loopmidi.html to set up a virtual midi device, and set it as output in ableton and input in resolume.
you can also do this between to computers, via the network midi, and trpimidi: http://www.tobias-erichsen.de/software/rtpmidi.html over ethernet.
Daisuk
Post by Daisuk »
ravensc wrote:On mac just add a port to the IAC device in Midi studio, and set it up as output in ableton and input in Resolume.
Sweet! Thanks a lot for the info. I'll try that out tomorrow. :)
