Hoping you can guide me, the reolume 5.1.3 close unexpectedly and that happend to me in several times when I'm playing multi-layer jpg loaded columns with color effects. I'm working in a theater using archives in jpg and clips on dxv. Mandatory before each show I have to adjust the output to the set, during a play, the program it's running for two hours and non stop.
Can you help me to undestand what's going on and What might be the problem?
The computer it's a:
Mac Pro Mid 2010
Quad-Core Intel Xeon
Memory 32gb 1066 MHz
MacHD
2x ATI Radeon HD 5770 1024 MB
OSX 10.10.5 Yosemite
Wishing the best to all.
Arena 5.1.3 Quit Unexpectedly several times
antonio.cordero
OnlineZoltán
- Team Resolume
Re: Arena 5.1.3 Quit Unexpectedly several times
short answer, converting your jpgs to dxv should solve your problem.
for longer answer see here viewtopic.php?f=12&t=11949
antonio.cordero
Thank you, it was really heplful, problem solved.
