Hi, sorry again, but if I run arena as administrator (win 10) Im not able to drag a file from desktop to deck, only from arena browser, I have tried to change permission for whole c drive and still not able to do so, Is it bug or am I doing something wrong??
TY
cant drag files from desktop
OnlineZoltán
- Team Resolume
Re: cant drag files from desktop
which file types are you trying to drop?
any. jpg, png, dxv-mov. max full hd. no prob from resolume browser, no able to do it from win desktop. same file.
if not using run as admin, there is no prob with dragging from anywhere (desktop included)
please dont tell me to use correct format, cause thats what am I exactely doing.
OnlineZoltán
- Team Resolume
so you are logged in as normal user, and start resolume by right-click run as administrator?
There is an little Pencil icon above your posts, you can use it to edit, so you don't need to reply to your last post
so here is what i found out
win 10 preinstal at new comp - you are ask to create administrator account for using the system. once installed, you have admin rights. but, you are not total admin of everyything, there is a hidden real admin acc. run cmd, write "net user administrator *, set the password, confirme password, then write net user administrator /active:yes. New one will appear, check switch account, there is a new user. this is real admin i think, but the thing is there are no win app running after this one without changing registry, thats what im not going to do.
final - u cant run arena as real admin without changing reg to acces all win app. this explain my prob i thing. simply not running it as admin.
