Bit of an odd problem I wonder if there might be any ideas on.
We have a Retina MacBook Pro for use in live shows with Resolume Arena 4, Ableton Live 9, Max4Live. We trigger clips via OSC sent from Ableton Live. It's always been fine with pretty huge projects.
We created an Arena project on a desktop PC and have transferred it onto the MacBook Pro. All the settings look the same as any other project and while the project is large it's certainly not larger than any other. When triggered via OSC we're getting about 0.25-0.5 second delay before a clip triggers.
This doesn't happen on any of the other projects on the Macbook. Only the one which was built on the PC.
We could rebuild the set on the Macbook Pro but it's 23 Layers and 210 Columns so I'd really rather not.
Any thoughts why this might be happening?
Many thanks,
Chris
OSC latency problem when copying projects to new computer
cevansroberts
cevansroberts
Re: OSC latency problem when copying projects to new computer
Worked out my own solution.
For anyone this might be useful for, for some reason opening the project in Arena 4.1.8 on the Mac fixed the OSC latency. The project was put together on Arena 4.2.2 on the PC and initially tried playing back on 4.2.2 on the Mac).
Seemed to have the same problems with subsequent builds so maybe something in the way Arena is handling the OSC messages in later versions.
Anyway, hopefully this helps someone else in the future.
