Blackmagic Design DeckLink Duo 2
Serg
Post by Serg »
Anybody use this with Resolume? Is it really can support 4 inputs 1080p60?
Meptik
Re: Blackmagic Design DeckLink Duo 2
Post by Meptik »
Correct. All of our systems have these cards and can do this. Either 4 inputs or 4 outputs at 60P.
Yes we use that as well and it works great!
Keep in mind that you'll have to set it up to work that way and it's not straight forward but if you search the forum you'll find some threads on the topic.
cormacokane
Post by cormacokane »
Hi . I'm trying to get my decklink duo working with resolume and I can get only one output to work at a time and also only when I select pal or ntsc as the output format.
Is this correct?
Any tips on correct settings on outputs to use decklink successfully with resolume would be much appreciated.
Cormac
P. s. I am aware of the correct connector settings on the decklink card for the sdi outputs .
How do your settings look like now?
Could you please send us the Resolume log file via the feedback tab in preferences?
BMD cards are a pain but they work. Last time I used one I spent 3 hours trying out various drivers until I found one that worked (This was in 2020). Once they're up and running they should be pretty stable. It's a LOT of work in their software to configure and minimal work in Resolume. The outputs will not be sync'd FYI.
