Export Input Selection Map to imagefile
MRmP
Post by MRmP »
I tried to search for this feature request, as I'm most definitely sure im not the first to have this request.
The Input Selection tab in Advanced output is oftentimes moved and positioned to account for the actual stage layout, whilst the Output Trans.. is mostly for how the LED processor wants the mapping.
So what I'd would love is to be able to export the input selection (With gridlines for each slice). So I easily can drag this into Photoshop, After Effects etc. And match my input layout perfectly.
Ive noticed the "Show grid" -> show slice grid, but this sends out the grid for the output mapping.
Re: Export Input Selection Map to imagefile
open advanced output,
select your screen or slice you want to export
open the Presets dropdown,
on the bottom, you'll see Export to SVG.
go to http://svgtopng.com/ and convert your svg files to png if needed.
MRmP
Post by MRmP »
Oh, that was easy!
Thank you :)
