Separate Clip Start & Loop
jate
Post by jate »
I'd like to find a way, or this is a feature request, to designate a clip's start, but separately designate where it loops.
Here's what I mean:
Thoughts?
Re: Separate Clip Start & Loop
feature request,
+1
currently a workaround I use in these cases
I duplicate the file, in the same layer to the next column
set layer transition time to 0
set the first clip to play until the loop in point, play once mode,
set autopilot to play next clip for this clip
set next clip to play from the loop in to loop out point, set clip to loop
this way when you launch the lead in clip it will automatically switch to the next (looped)
jate
Post by jate »
ravensc wrote:feature request,
+1
I figured this would be the suggested method, thanks - it will be a lot of time to set that up for each clip, but I guess it's the only way to go about it currently.
For reference, the reason for this is I generally like to have a big animation into a subtle animation.
I don't know if I need to put this somewhere else for a feature request, but I'm sure our friend Joris can move it for me if so, thanks!
