Scrolling option is broken?
SystemD
Post by SystemD »
When i choose in preferences the option "Scroll Layers end Clips into view", nothing happens.
My clips are triggered with OSC, but they are not scrolled :(
Windows 10 / Arena 5.1.4
Re: Scrolling option is broken?
you need the "update clip panel on external trigger" to be enabled too.
SystemD
Post by SystemD »
yes, that's what i do, but nothing...
SystemD
Post by SystemD »
https://youtu.be/eiI7Z_RVmbA
So WMG just blocked your video in my country? I highly doubt there is copyrighted material in it.... so weird.
Could you share a Dropbox link so I can see what's going on?
Can't play the video either.
works for me both on osx and windows 10.
you could do a hard workaround by sending /layerX/clipY/select int 1 after the connect for the same clip
SystemD
Post by SystemD »
Crazy, no audio on the video !!
And with vimeo? :
well, no idea why this would not work for you.
which program is that sending the osc messages?
SystemD
Post by SystemD »
could you upload that patch, I am downloading max now.
