hi
when i open the screen setup der is only monitor 1 and dvd max (i dont know what this is), but my grafik card has 1 svhs and two monitor outputs.
on windows they are working whitout problems ( multidesktop)
i have a radeon 7000 whith 64mb
anybody knows this problem?
should i by an other grafikcard?
thanx
elias
resolume don't know my grafikcard outputs
r u sure that you installed propper device drivers supplied with your card?
as far as I know, resolume takes the displays from the system
it sounds like a conflict
dvd max is something for the matrox based cards as far as I remember so you dont have to turn it on unless you have a propper matrox gfx card supports dvd max feature...
hope dat helps
bw
t
hope dat helps
bw
t
