Effects
Sofiafio
Effects
Post by Sofiafio »
well, I've Resolume 4 and was working in it, but when I open today there were no effects, they're lost, how can I solve it?
HELP please :roll:
Re: Effects
Have you tried re-installing your software, or renaming your Resolume user folder (inside your documents folder) to something like "Resolume old" then restarting the software.
Re: Effects
My recommendation would be to follow these instructions:
Support FAQ wrote:Go to the Resolume folder in (My) Documents. Move the config.xml file, disconnect any external devices and try to start again. This will force Resolume to start with the default comp and preferences. This should bring things back to normal.
