Datapath VisionSC-DP2
lightbx
Post by lightbx »
Has anyone successfully used this card for video capture into Arena? It's in a PC spec I'm looking over, looking for confirmation from a user that it appears in the Sources tab properly.
If not, I'll just be first to report back. I feel confident,
Given the Datapath website's page on the card reads "Any application compatible with Windows® DirectShow technology can use the VisionSC-DP2 due to it's built-in WDM support." No real reason to doubt Datapth, just making sure. Thanks!
Re: Datapath VisionSC-DP2
Up until this last month when I sold it, the VisionSDI2 works great! I had to rotate my z axis on input, but other than that, it was a solid card. If these 2 cards are built on the same architecture, then it should be good to go.
lightbx
Post by lightbx »
Awesome! Thanks for the confirmation. Can it be used as an output, like a Blackmagic capture card, or is that feature specific to Blackmagic?
I only used mine as input. I sold it last month or I would test it teal quick for you. sorry
