Animate Position X On Clip
When Animating Position X on the Clip level (In my case: ping pong style) the start and end points always end back up at the default composition size (In my case: 1920 x 1080), Even though I hardcode them to something like -650 x 650.
They only reset when you re-open the comp. You can change and sac the settings and they will work until you close the comp. When yo re-open the start and end values are reset (as is the direction of playback too?? pretty sure on that one)
Re: Animate Position X On Clip
I can recreate the ranges reseting, (created a ticket #9586)
but not the play direction.
Is that the parameter animation direction, which mode?
ravensc wrote:I can recreate the ranges reseting, (created a ticket #9586)
playback direction is good. false alarm.
