Rings Thumbnail is a big yellow X
zhukang
Post by zhukang »
What should I do
Re: Rings Thumbnail is a big yellow X
Please try to place the rings from sources panel directly,
If that also doesn't work, please upload your arena log file, and describe your system configuration.
francoe
Post by francoe »
Have the same yellow X on windows 7. Will try to send report.
you can also use the Feedback tab in Preferences.
