MEMORIZE most used effects
JAMES LOST
Post by JAMES LOST »
Dear Team Resolume,
I know, I am always late.
Especially when it comes to type some serious matters in a forum. :-)
My 'issue':
When I want to use a effect on clips that I used before, I have to scroll down, or type over-and-over, to get this effect. So I was wondering, is it possible to create a sort of favorite box of my most used Resolume effects? So I can store them for fast use? (brightness/contrast, Invert, Add substract, Strobe)
i'm looking forward to Resolume 6.
Kind regards,
Seppe Ovink
JAMES LOST
Protect me from what I want.
Re: MEMORIZE most used effects
visions
Post by visions »
+1 here!
Ferloz
Post by Ferloz »
Hi, I bought Arena 6 and I am very happy with it. Almost a year since James Lost asked for this very simple and usefull "user most used effects shortcut" (above effects directories?).
Is that so difficult to do? Thanks for your work and concern about users.
Are you aware you can type a query in the search box?
If you need to pull up a limited list, try this: add "Fav_" or "*" as a prefix to the name all your favorite presets using the [Manage Preset] menu, then type "Fav_" or "*" in the search box and all your favorite presets will be right there.
