R6 Beta 2 - SDI output issues
On MacOS 10.12.6.
With the UltraStudio SDI USB3, any adjustment of the RGB or Opacity sliders make the image start flicker but the RGB seems to adjust properly.
With the UltraStudio Mini Monitor, any adjustment of the RGB or Opacity sliders make the image disappear. The RGB seems to adjust properly from 0 to 100 but not from 0 to -100. So if I go to -1 R, the image is black but at 100 or -100 it's all red.
Contrast & Brightness work fine in both instances.
Re: R6 Beta 2 - SDI output issues
creating a ticket, #9702
the UltraStudio Mini Monitor has a HDMI out also right, could you check if the same happens using the hdmi out also?
Seems to be working fine in R6 Beta 3 with both the Ultra Studio Mini Monitor and the Ultra Studio SDI USB3 in both HDMI and SDI.
As a note, I can actually get both signals out at the same time on both devices which is very cool!
EDIT: I think I may have spoken too fast! I was able to recreate the same problem again (not sure how!) but it went away on its own this time around.
Oaktown wrote:I was able to recreate the same problem again (not sure how!) but it went away on its own this time around.
I experienced the same with my Intensity shuttle, once it doesn't work then on the next resolume restart it does.
