2 Blackmagic Decklink Quad Cards| v6 Beta 3
philmcrackin
Post by philmcrackin »
Alright I got my Hackintosh rig outfitted with 2 Decklink Quad capture cards (First version, not the second iteration).
In Resolume Arena 5.1.4 under "BlackMagic Capture Devices" The inputs show up like this and can display all 8 camera inputs:
Decklink SDI 1
Decklink SDI 2
Decklink SDI 3
Decklink SDI 4
Decklink SDI 5
Decklink SDI 6
Decklink SDI 7
Decklink SDI 8
In Resolume 6 Under "Capture Devices" the inputs show up like this
Decklink SDI (1) - SDI 1
Decklink SDI (2) - SDI 2
Decklink SDI (3) - SDI 3
Decklink SDI (4) - SDI 4
It only reads four camera inputs off one Decklink Quad, each input is the same camera feed, almost like it knows the other card is there but can only display 4 inputs off one card. I will install Windows very soon and report back to see if I have the same issue.
Re: 2 Blackmagic Decklink Quad Cards| v6 Beta 3
sounds like the same as in viewtopic.php?f=12&t=15046
right?
philmcrackin
Zoltán wrote:sounds like the same as in viewtopic.php?f=12&t=15046
right?
Correct, it sounds like the exact same issue. I should have checked other threads first to see if other people had the same issue as me before posting this thread.
