SECOND MONITOR OUTPUT PROBLEMS
styledope
Post by styledope »
HI
I`am bought a G-FORCE 6600 , and i got a big problem whit resolume 2.2 ( and 2.1 ) .
Resolume works well..... until i try to lunch second monitor output .
It`s crash badly ( stop working , responding , and it`s close by windows after few sec.) .
I try several options in nvidia configuration panels but it not resolved a problem .
AAA . I`ve try the RESOLUME 1.5 is working fine , no problems whit second monitor output ---- cool .
perhaps is a problem whit this f..... nvidia drivers or whit gforce 6600
MY HARDWARE CONFIGURATION IS
AMD ATHLON 2,8 , 2X512 mb , GFORCE 6600 (msi),
WINDOWS XP ( no service pack )
DIRECTX 9c
and last DETONATORS --- 7.1.8.9 from nvidia home pages ( but i have try several drivers .
PS ; I`ve try also the gforce 6600 gt on my second computer ( pentium 2,4 windows xp ) and the
effect are the same , resolume crash
Anonymous
Post by Anonymous »
I get the same problem, with an ati 9800, worked great and just stopped working. I rebuilt my computer hoping this would correct it, and still won't work. I can't figure out why I can change screen settings
Anonymous
Post by Anonymous »
radeon9200,windowsXp....same problems. It's time to do something!!!!!!!!!!!!
check some other threads, for more info, but missing or incorrectly installed audiodrivers could cause this problem (we have fixed this already and will be no problem anymore for the next release.
It could also be cirus cranner that is causing the crash: http://www.resolume.com/forum/viewthread.php?tid=1611
Sooooooz
Probs with dual output
Post by Sooooooz »
I'm also now having problems with version 2.2 crashing when I try to enable dual output. You point to the audio drivers, can anyone advise how to check whether it's due to missing/incorrectly installed audio drivers. If it is, what can I do about it? Any help much appreciated as due to play in a couple of days...
Anonymous
Post by Anonymous »
I have the solution to this problem, i discovered it by accident, i had a gig and the day after i couldn't get my resolume 2.2 to work.. when i realized that version 1.5 worked fine i started mixing some files between folders (2.2 & 1.5) i found out that when i deleted the folder "decks" the program crashed, but with an error window i had never seen before.. don't ask me why, but somehow it ocurred to me that if i had that error window active when hitting the "apply" button in screen configuration something could happen.. so i tried.. i deleted the "decks" out of the resolume 2.0 folder.. i opened it, tried to load a movie.. error window.. closed the program but kept that helpful error window.. opened resolume 2.2 (with 2.0's error still active) and tried to apply the second monitor fullscreen mode.. it worked!
perhaps some resolume tech support guy can explain this, but it's kinda crazy that an error strikes out a different one.. try it, perhaps it works for you to ;)
Pardon my english (i'm from argentina :D)
zeketech
Post by zeketech »
you must see the first monitor in preview mode and the 2nd monitor in fullscreen mode.
In both monitor´s configuration windows must apear the name of your video card...
(I´m sorry from my english, it´s so bad... i´m from spain)
iog
Post by iog »
i have a problem, i can't do the setup of my external window when i want to play it
