Copied Clip = linked Clip ?!
thomgee
Post by thomgee »
Hi there,
it happens some times, that if i copy a clip with effects by drag & drop w optionkey , to a different layer, the Clip seems to be linked.
So if i change the properties of the Clips (Effects ... ) the other clip get changed too.
if i copy with keyboard (cmd c) those "Links" seem to be gone.
is this purpose or a bug?
If purpose, where is it documented?
Arena 6 & 7
MacOS 10.14.4 Mojave
Macbook Pro 2017
3.1Ghz | 16 Gb | Radeon 560 4GB
Re: Copied Clip = linked Clip ?!
thomgee wrote:it happens some times, that if i copy a clip with effects by drag & drop w optionkey , to a different layer, the Clip seems to be linked
Definitely a bug.
Please attach your composition to a post here zipped, or send it to us directly to mail@resolume.com so we can take a look.
