Mapping different channels on MIDI controller (RESOLVED!)
ake93
Post by ake93 »
Hi everyone,
I have an Arturia Beatstep MIDI controller which has 16 pads and16 channels. I can switch from a channel to another simply pressing a button on the controller, BUT, Resolume seems don't recognize them.
For example:
(entering the mapping settings and press:
Pad "1" on channel "1"->clipA
(then i change channel on the controller and press:
Pad "1" on channel "2"->clipB.
Even if i change the channel on the controller and press the pad 1 it triggers the clip1 everytime, even if i set "channel2" from the option below during the mapping. Please help i have 16 pads for 16 channels so more than 200 pads potentially but im only able to use 16!!
Thanks and sorry for the english, i hope my issue is well explained
drazkers
Re: Mapping different channels on MIDI controller (not working)
Post by drazkers »
ake93 wrote:Hi everyone,
For example:
Are you on R6? Could you go into preferences>midi and take a picture of the midi log? Then we can see exactly what channels/notes your device is sending?
Works for me with R6.
Are you on R6 or R5?
Out of curiosity, are you exiting the mapping mode when you are changing the Global MIDI Channels on your Arturia Beatstep?
ake93
Re: Mapping different channels on MIDI controller (RESOLVED!)
Post by ake93 »
Ok I've finally understood what was the problem. If you have an Arturia Beatstep controller, you have to open Midi Controller Center, then in "Performance Data" change the "Sequencer channel" to GLOBAL. Now Resolume works perfectly with the pad. Thank you everyone for the attention and the time spent trying to help me.
