Decklink Outputs Master Fader screens go white
servant812
Post by servant812 »
When we use decklink outputs and then fade the master fader down the screen goes white as it fades out rather than actually fading out. tried a bunch of different settings and can't fix it.
Re: Decklink Outputs Master Fader screens go white
Which decklink device do you have?
Which Resolume version?
Try putting all your layers into a group and use the group master to fade until we have a fix.
