6.0.2 update doesn't start
theLABVisuals
Post by theLABVisuals »
Just installed update via auto-updater and unable to open Resolume Arena 6.0.2.
Bombs out each time attempted.
Have rebooted.
Still bombs.
#sadface
Screenshot 2017-12-12 11.15.19.png (54.93 KiB) Viewed 14850 times
Re: 6.0.2 update doesn't start
theLABVisuals wrote:Just installed update via auto-updater and unable to open Resolume Arena 6.0.2.
Have rebooted.
Still bombs.
#sadface
That sucks!
Please zip the Documents/Resolume Arena 6/preferences folder, then rename it, so Resolume starts with the default settings, that should get you going.
Please send us the zip file to mail@resolume.com so we can take a look what might go wrong.
Also please also send the Bugsplat error report when Resolume starts up the next time.
Thank you!
theLABVisuals
https://www.dropbox.com/s/yj8foxslumz1y ... d.mp4?dl=0
Deleted old version // Rebooted // Recorded.
theLABVisuals
Avenue 6.0.2 works as expected by the way.
Ta
theLABVisuals wrote:https://www.dropbox.com/s/yj8foxslumz1y ... d.mp4?dl=0
You opened the Report details once for a second.
There was something about flanger...
Please copy paste the report text to a txt file and upload it zipped.
theLABVisuals
Emailed.
theLABVisuals wrote:Emailed.
Thanks, so the quick solution I can give you and works on my machine is to
remove the Arena.app from your apps folder first,
install 6.0.1 no footage installer,
then install the 6.0.2 no footage installer, without removing the Arena.app.
Let me know if this works for you!
This issue is now fixed, new installers for 6.0.2 for mac are uploaded. If you ran into this issue please download again.
Grimm90
Post by Grimm90 »
Auto update works for me , but makes a weird "mistake" on win10 x64
1) Open resolume 6
2) ¨¨Auto update box¨¨
3) Start updating = Can't update , close appps first
4) Resolume is already open but asks the 'quit confirmation' , you don't see it it's minimized.
5) try to install anyway = cant copy certain files = errors
6) quit resolume running in background , updater stays .
7) update succesful
Grimm90 wrote:Auto update works for me , but makes a weird "mistake" on win10 x64
You should have a better experience when updating 6.0.2 to the next version.
