Hi everyone,
So Ive decided to try out the Sager NP8952 with 1070 MaxQ, and so far its been nothing less than a nightmare with my FPS.
Windows 10
Nvidia 385.89 (rolled back from current 388, same issues listed below happen with every nvidia driver ive tried)
Build 1703
V-Sync: Off (prefer it on, have it turned on with my alienware and it works perfectly)
Frame Rate is 140+ with VSync off and 60 with VSync on, as it should be...UNTIL I OPEN THE ADVANCED OUTPUT. The second I open the advanced output I'm looking at a drop from 140+ FPS to 25-40FPS. If I have VSync ON, I go from 60FPS to 9-20FPS. This happens the second I open advanced output, even if I dont have a display connected!
I'm wondering if this is because of some MaxQ BS, or if there's something I'm missing here. I've matched all settings to my alienware and played around with almost every setting there is in Nvidia control panel. I've got nowhere left to go, except to return this laptop, which I dont want to do because I love its portability.
Sager NP8952 with GTX 1070 MaxQ Low FPS
smoresahoy
Re: Sager NP8952 with GTX 1070 MaxQ Low FPS
Your build looks very similar to mine, with the GPU being the only difference.
Have you sent a feedback log to the dev's from within your application?
smoresahoy
No, Ill do that. Whats your setup???
2017 Razer Blade (gtx 1060)
Windows creator update (not the fall)
Nvidia driver 385.69
high performance set as default render'r and v-sync off.
resolume comp set to auto.
I'm getting 140 fps idle and about 80-100 fps when running 2-3 layers at 1080p (with fx)
smoresahoy
Arvol wrote:2017 Razer Blade (gtx 1060)
How about with V Sync Turned on? I really cant stand screen tearing with V Sync off.
it's set to 60
joshuadmello
Im having the same problem with the NP8954.
And it wont let me downgrade to 385.69. It says the drivers are incompatible with the hardware :/
Any ideas?
Any ideas?
