R6 - New Year's Countdown
Empyfree
Re: R6 - New Year's Countdown
Post by Empyfree »
Hi Oaktown. Thank you for making this project available.
This is my first time opening touch-designer, where would I set the lat/long as you mention above?
edit.. nevermind! found it!!!
Takeya
Post by Takeya »
Hi, Im brand new to touchdesigner. Where is the change to adjust latitude and longitude?
For those of you planning to use my TD script for New Year but are wondering how to adjust the time or latitude/longitude to be exact with the countdown , here is a short video to show you how:
Happy New Year everyone!
Here is an updated version of the New Year's Countdown TD script with artwork for 2020!
This year I made the countdown timer available as an NDI and Syphon/Spout Out for those of you who don't want the graphics.
The script is set to trigger at Midnight for the San Francisco Bay Area latitude/longitude.
2020 NYE Countdown.zip
(1.8 MiB) Downloaded 933 times
The way it's currently setup, it triggers both the video and png file. Take a look at the video and it'll show you what happens.
Scartio
Post by Scartio »
Hi there! Is there an 2020/2021 version of this one?
Scartio wrote: Wed Dec 16, 2020 20:26 Hi there! Is there an 2020/2021 version of this one?
Just edit the old version, it should be pretty straight forward if it doesn't already auto update each year :)
DHoude
Post by DHoude »
The 2019 is a Movie file. That will not update. But the fireworks are seperate. Perhaps just replace that with a 2020 clip that you have. Here is a quick hint to get started.
