R6 - New Year's Countdown
EDIT: MAKE SURE TO DOWNLOAD THE MOST RECENT VERSION (V5 as of Dec 31, 2017 at 09:00 PST)
Here is a Touch Designer comp you can use to build your NYE countdown in Resolume 6.
This should work on both PC & Mac with the free non-commercial Touch Designer 099 license. This is a skeleton build with several syphon/spout outputs so that one can hopefully create something cool with it for NYE. To get the right time on the clock, you'll need to set the exact latitude/longitude for your location (the attached file is set for Oakland CA).
All I ask is that if you end up building something cool with it in Touch Designer and Resolume, you share it back on the forum for everyone to use it.
NYE Countdown from Oaktown.toe.zip
(5.26 KiB) Downloaded 1346 times
Re: R6 - New Year's Countdown
Here is an improved version of the Touch Designer comp I posted yesterday. This one has a simpler node structure and has leading zeros for mins, secs, and msecs for the main outputs.
NYE Countdown from Oaktown V2.toe.zip
(5.33 KiB) Downloaded 1242 times
For those of you that are not familiar with TD, for any of the Syphon/Spout Out TOPs, you can easily change the output resolution as well as the font type, size and color in the Text TOPs.
V3 of the Touch Designer Countdown comp. This one includes python scripts that change the plural & singular of hour(s), minute(s) and second(s) based on numbers.
NYE Countdown from Oaktown V3.toe.zip
(5.94 KiB) Downloaded 1362 times
takehiko
Post by takehiko »
what happen when arrive midnight? do it restart from 23:59:59:999? or there is written: happy new year!!!
Something like this?
Here is V4 where I added a Python script to trigger an event set for midnight:
NYE Countdown from Oaktown V4.toe.zip
(7.09 KiB) Downloaded 1399 times
You can change the movie and picture files in Touch Designer and test the comp by changing the hr, min, and sec values in the trigger_script. Just don't use leading zeros in the script.
brandonL
Post by brandonL »
Thank you for this!
My pleasure! Hopefully that works for you and everyone who downloaded it.
Here is V5 (final one for this year!) which makes the hh:mm:ss visual count down more in line with the way people will be counting down in the last 10 seconds. The trigger is still at the same time but this makes more sense if you use the counter without msecs.
NYE Countdown from Oaktown V5.toe.zip
(6.84 KiB) Downloaded 1402 times
Here is a simplified version of the TD script I shared last year.
2019 NYE Countdown.zip
(1.66 MiB) Downloaded 1577 times
As a reminder, to get the right time on the clock, you'll need to set the exact latitude/longitude for your location (the attached file is set for Oakland CA).
You can change the movie and picture files in Touch Designer and test the comp by changing the hr, min, and sec values in the trigger_script. Just don't use leading zeros in the script. Visually, it appears that setting secs to 1 and msecs to 500 works best
Screenshot 2017-12-29 11.02.02.png (127.48 KiB) Viewed 24702 times
fernando.jp
Post by fernando.jp »
Very good, could create one with the possibility to put the countdown so that we can modify for the count to end at any time, so we would not be bound to use only once a year.
Take a look at the video, you can adjust the time easily to match your needs.
