Webcam ?
meek
Webcam ?
Post by meek »
Hi all,
Can anyone recommend a USB webcam to do a live camera feed into Resolume 2.2 ?
Basiclly want to do a simple live cam feed of the decks / dj,
But I dont wanna use dv / firewire device for this one.
Distance from the pc to the dj is unkown (so mabe a wireless one would be best?) and it will need to work under low light conditions - and obviously not kill resolume !!
Any help would be great,
ta
James // http://www.meek.tv
dreamtk
Post by dreamtk »
Hi
I've used the Logiteck 4000 pro for the same thing. It's very good, as long as it's close to the DJ's, otherwise light will be a problem :)
