OSC in Resolume 6
Antanton
OSC in Resolume 6
Post by Antanton »
Hi!
Where do I fint the OSC adress when in "edit osc" mode? Before it showed up in the left down corner but now I can´t find it..
Re: OSC in Resolume 6
It will be where your effects and sources are located at.
Antanton
Post by Antanton »
yes but in this tab it only says "Osc type tag int o or 1"wherever I click
Rearrange the panels a bit so the Shortcuts panel can be higher, now it crops the list itself in your screenshot.
Antanton
Post by Antanton »
Haha great! it needs to be really high. thanks!
