update policy from 6.x to 6.y
Schaupau
Post by Schaupau »
i just wanted to say, that the old R4-Way of installing the new version beneath the old version so, that Resolume 4.1.1 and Resolume 4.1.2 is still usable was a great way for dealing with troubles.
Are you doing the same policy with the 6-Versions?
Best,
Schaupau
Re: update policy from 6.x to 6.y
No we're not.
Resolume 6 updates overwrite the old version.
You can rename the old version's install folder before installing the new version, and both will run fine.
