Transforming Clip Scale in one Axis
Nick-G
Post by Nick-G »
Anybody know why I can't expand the scale parameter on my content's transform options. I can't find any way to expand the total; scale to individual x and y components as it says you can do below.
I am using Resolume Arena 4.
Scale
Adjust the size of the content, proportionally to its original size. Expanding the parameter will let you scale the width and height individually.
He2neg
Re: Transforming Clip Scale in one Axis
Post by He2neg »
there are numbers you can adjust to set the high / wide of your clip.
cant give you a screenshot right now but you´ll find them...
~Berlin~
Nick-G wrote:Anybody know why I can't expand the scale parameter on my content's transform options.
You can find the manual for Resolume 4 here: https://resolume.com/manual/en/r4/start
Or bundled with your application as pdf.
In Resolume 4 the Width and Height parameter sliders are the ones you can use.
We are at version 6 now, so on our Support page you'll find information about Resolume 6.
