sequencing
komart663_
Post by komart663_ »
did anybody ever try to sync resolume with an external sequencer ( as i try and use a tr 707 ) ?
thanks for any tips
cheers
komart663
yes we have done this with a Roland HPD15 ... works fine ...
komart663_
ok ,but how do i do the midi mapping ? shall i use first a midikeyboard and then render my pattern with my rythmbox or shall i just do the midi mapping with the rythmbox ?
if you can send one note with your rythmbox i,d say use the midibox ... but try and see what works best ... and then let us now here on the msg board ;-)
