Resolume Avenue 6 failed to initialize
makenzi
Post by makenzi »
I'm trying to run Avenue 6 on my laptop (core i7-2670QM, 8GB RAM, Nvidia GT555m, win7 64bit).
This notification pops up every time I try to run it.
Is this really because I'm missing some sort of software? I've already installed recent version of openGL driver.
Any help in this matter would be appreciated.
Thanks ;)
Daniel
Re: Resolume Avenue 6 failed to initialize
Post by Daniel »
hey makanzi,
Did you also update to the latest Nvidia Driver?
makenzi
Post by makenzi »
Yes, I have the latest version of Nvidia driver, still doesn't work...
Pease update to 6.0.6,
and if it still fails to start please send us your log file.
on win10 it's in C:\Users\[username]\AppData\Roaming\Resolume Arena
on OSX: ~/Library/logs/Resolume Arena/
makenzi
Post by makenzi »
Resolume Avenue 6.0.4 60455
Log started: 1 Mar 2018 1:17:33am
Logging has started
Initialise JuceResapiApp
Initialise ResApi
INFO: Initializing Resapi
INFO: Created ParamCollection
INFO: Created TaskManager with 6 threads.
INFO: Created InputController
INFO: Created DeviceChangeDetector
INFO: Creating VideoFormatManager
INFO: Registering basic formats
INFO: Registered 5 formats
INFO: Created VideoFormatManager
ERROR: Could not create instance of IDeckLinkDiscovery - DeckLink drivers may not be installed or not up-to-date.
INFO: Creating NDIVideoServerManager
INFO: Initializing NDI library
INFO: Successfully initialized NDI library
INFO: Created NDIVideoServerManager
INFO: Creating VideoSourceManager
INFO: Created VideoSourceManager
INFO: Creating DisplayCollection
INFO: Created DisplayCollection
INFO: Chosen pixel format: 4
INFO: Chosen pixel format: 9
ERROR: ra::Context::createOffscreenContext: Failed to create context for OpenGL 3.2.
ERROR: Escaped from error in ra::ContextManager::initialize(26): Failed to create primary context.
ERROR: Failed initializing Resapi, Contexts are required for rendering.
Prepare for shutdown
Force Stop Recording
Setting up default composition.
Composition Prepare for Shutdown
INFO: Initialise took: 7.33137 seconds
Shutdown sequence started
Composition Shutdown
Stop renderer
Stop Server if running
Clean up renderer
Save Application and VideoEngine settings
Serialize application model
Serialize video engine
Log started: 1 Mar 2018 1:22:32am
Logging has started
Initialise ResApi
INFO: Initialise took: 1.65617 seconds
Stop renderer
Clean up renderer
Log started: 1 Mar 2018 1:25:08am
Logging has started
Initialise ResApi
INFO: Initialise took: 53.36698 seconds
Stop renderer
Clean up renderer
Log started: 1 Mar 2018 9:41:01pm
Logging has started
Initialise ResApi
INFO: Initialise took: 3.69146 seconds
Stop renderer
Clean up renderer
Resolume Avenue 6.0.5 60496
Log started: 1 Mar 2018 10:06:58pm
Logging has started
Initialise ResApi
INFO: First time OpenGL usage, initializing extensions.
INFO: Registering window class.
INFO: Successfully registered window class.
INFO: Successfully initialized extensions.
INFO: This system supports OpenGL version: 3.1.0 - Build 8.15.10.2455
INFO: Initialise took: 2.01492 seconds
Stop renderer
Clean up renderer
Create preferences file (config.xml)
Write preferences XML (config.xml)
Clean up UI
Save Video Effect Presets
Save Source Presets
Locate preferences directory
Save Screen Setup Simple Settings
Save shortcuts and presets
Stop output shortcut managers
Clean up LookAndFeel
Clean up HelpController
Clean up Compositon
Deinitialize AudioEngine
Clean up Audio Engine
Clean up Video Engine
Clean up RecordingController
Clean up ApplicationController
Clean up OscController
Clean up MIDIController
Clean the UI Factory
Clean up Application Object
Shutdown JuceResapiApp
Release ResApi
Shutdown ResApi
Deleting myself
Log started: 7 Mar 2018 3:20:40pm
Logging has started
Initialise ResApi
INFO: Initialise took: 32.60809 seconds
Stop renderer
Clean up renderer
Clean up UI
Save Source Presets
Clean up Compositon
Release ResApi
Shutdown ResApi
Deleting myself
Log started: 7 Mar 2018 3:43:14pm
Logging has started
Initialise ResApi
INFO: Initialise took: 36.29325 seconds
Stop renderer
Clean up renderer
Clean up UI
Save Source Presets
Clean up Compositon
Release ResApi
Shutdown ResApi
Deleting myself
Log started: 14 Mar 2018 5:57:43pm
Logging has started
Initialise ResApi
INFO: Initialise took: 2.86639 seconds
Stop renderer
Clean up renderer
Clean up UI
Save Source Presets
Clean up Compositon
Release ResApi
Shutdown ResApi
Deleting myself
Log started: 14 Mar 2018 6:01:50pm
Logging has started
Initialise ResApi
INFO: Initialise took: 1.42474 seconds
Stop renderer
Clean up renderer
Clean up UI
Save Source Presets
Clean up Compositon
Release ResApi
Shutdown ResApi
Deleting myself
Log started: 15 Mar 2018 2:48:50pm
Logging has started
Initialise ResApi
INFO: Initialise took: 1.67221 seconds
Stop renderer
Clean up renderer
Clean up UI
Save Source Presets
Clean up Compositon
Release ResApi
Shutdown ResApi
Deleting myself
Resolume Avenue 6.0.6 60545
Log started: 28 Mar 2018 9:04:30pm
Logging has started
Initialise ResApi
INFO: Registered 4 formats
INFO: Initialise took: 14.44692 seconds
Stop renderer
Clean up renderer
Clean up UI
Save Source Presets
Clean up Compositon
Release ResApi
Shutdown ResApi
Deleting myself
So, according to your log file the driver for the GPU you have doesn't support openGL 3.2.
There is not much we can do about this I'm afraid.
