I know theres already a ticket for this but I just downloaded 6.0.6 and its still not fixed : (
Any updates?
Preview is cleared on clip trigger
Re: Preview is cleared on clip trigger
We have worked on that, it works now as intended in the ticket I believe (#10003)
- Clip preview is cleared when a new clip is launched manually,
- unless you launch a clip via OSC, MIDI or DMX, AND have Update clip panels on external trigger disabled.
- Auto auto pilot doesn't clear preview any more,
- Layer, group and composition previews are not cleared.
How would you like the preview to behave when you launch a clip?
joshuadmello
I generally keep my live camera feed preview on so I can always check the shots I'm getting.
And I also use strobes on piano trigger.
So every time I hit the button on my controller for my piano trigger strobes the preview gets killed.
I think disabling the Update clip panel on external trigger in General Preferences would work for you to keep the preview in this case.joshuadmello wrote:So every time I hit the button on my controller for my piano trigger strobes the preview gets killed.
joshuadmello
No man. Still gets cleared.Zoltán wrote:I think disabling the Update clip panel on external trigger in General Preferences would work for you to keep the preview in this case.joshuadmello wrote:So every time I hit the button on my controller for my piano trigger strobes the preview gets killed.
I just checked this out in Arena 5 and the preview stays. It seems like only 6 has this issue.
Any chance its going to get fixed?
joshuadmello wrote:No man. Still gets cleared.
I'd like to take a look, because when I uncheck the "Update clip panels on external triggers" checkbox in preferences, the preview is not cleared for me when I launch clips via midi.
edit:
Are your clips you trigger set to BPM sync? I see the preview disconnecting when I have a clips with auto pilot that are BMP synced.
joshuadmello
Not BPM sync. Its set to timeline. I mainly use this for piano trigger strobes. Here is a youtube link to show you what I mean. Excuse the water mark lol I just downloaded Arena on my work computer to record it.Zoltán wrote:joshuadmello wrote:No man. Still gets cleared.
Any chance its going to get fixed?Could you send us your midi preset, and the composition?
edit:
https://www.youtube.com/watch?v=7EMv0JxMh3c
In the above example I just mapped a key to the strobe piano trigger. But the same thing happens if I click click on the clip with the track pad.
joshuadmello
@Zoltan.
DId you happen to get a chance to check this out?
Yes,
the case in your video would be manually triggering a clip, where the expected behavior on our side is to have the Preview disconnected.
I assume you would like to keep the Preview, unless you explicitly clear the preview or select something other to preview right?
joshuadmello
Yes that's correct.Zoltán wrote:Yes,
But the exact same thing happens if I trigger it via my MIDI controller.
