Multiple Display VGA HDMI issues R6 Arena
RichVisuals
Post by RichVisuals »
Problem, Windows 10 identifies multiple displays without issue.
Resolume 6 Arena does not.
Chassis & Display Clevo P775DM3-G Chassi: 17.3" Matte 4K IPS LED Widescreen (3840x2160)
Processor (CPU) Intel® Core™i7 Quad Core Processor i7-7700k (4.2GHz) 8MB Cache
Memory (RAM) 32GB Corsair VENGEANCE 2400MHz SODIMM DDR4 (2 x 16GB)
Graphics Card NVIDIA® GeForce® GTX 1080 - 8.0GB GDDR5 Video RAM - DirectX® 12.1, G-SYNC
Driver Version 390.77
1st Hard Disk 1TB WD BLACK 2.5" WD10JPLX, SATA 6 Gb/s, 32MB CACHE (7200 rpm)
1st M.2 SSD Drive 512GB WD Black™ M.2 NVMe PCIe SSD (up to 2050MB/s R | 800MB/s W)
Sound Card Intel 2 Channel High Definition Audio + MIC/Headphone Jack
Bluetooth & Wireless GIGABIT LAN & KILLER™ WIRELESS-AC 1535 M.2 GAMING 802.11AC + BLUETOOTH 4.1
USB Options 4 x USB 3.0 Ports + 2 x USB 3.1 Type C Ports
Operating System Genuine Windows 10 Home 64 Bit - inc DVD & Single Licence
Version 1709 – Build 16299.309
Display Outputs :
Each change Setups 1,2,3 done with R6 closed and then reopened.
Test Setup 1
Primary Monitor (3840x2160) 150% Windows Scaling as Primary Monitor
Second Monitor (1680x1050) 100% Windows Scaling VGA converted from Display Port 1
Third Monitor (1920x1080) 100% Windows Scaling HDMI Converted from Display Port 2
R6:Ar. Options
Which is consistent throughout where all displays are connected.
R6:Ar. Identify
Test Setup 2
Third Monitor (1920x1080) Disconnected
Display 2 now shows correctly
Test Setup 3
Third Monitor (1920x1080) 100% Windows Scaling HDMI Output
Same output from R6Arena as Setup1
Test Setup 4
Disconnected Second Monitor And then Reconnected with R6 Open
Same as setup 1 and 3.
Test 5 disconnected both displays, plugged them into Display ports 1,2 the other way round and VGA last.
Same output from Resolume for 1,3,4.
This issue caused major problems at the weekend why trying to run 2 outputs, one to screens and one to a video stream, while running 2 displays (primary monitor and second hdmi for powerpoint.)
Resolume seems to refuse to output to a connected VGA device if there is a HDMI output also being used.
Any ideas? Never been able to get all three outputs working in R6 at once, windows has no problems.
Daniel
Re: Multiple Display VGA HDMI issues R6 Arena
Post by Daniel »
We are indeed seeing this problem cropping up. Could you please check if all your UI scalling is at exactly 100%? Including your main screen?
RichVisuals
Setting all screens to 100% scaling...
Windows Identified
Primary Display : as display 1 : 3840x2160
Second Display : 1680x1050 VGA (Display Port 1) then converted
Third Display : 1920x1080 HDMI output.
Resolume :
Output Menu lists same three screens in same identities.
However when selecting the "identify displays" option:
Screen 2 is showing as 1
Screen 3 is showing as 3
Primary screen not being shown with an identity colour display.
When selecting advanced output:I can get it to output only by selecting the same screens (1 and 3) even though display 1 still shows as the primary monitor (3840x2160) the output is being sent at (3810x2160) to the (1680x1050)
I think somewhere the software is getting confused as to which display is which. However I can confirm that with all scaling set to 1005 I am now able to get the output working for 2 of the three displays..
It doesn't explain why the main monitor is no longer identifiable in R6 though.... and I have had situations when trying to get this to work where the output display not addressed alters with disconnects and reconnects.
I have also had the all three blank issue but I believe that to be a driver failure after too many hot connections.
Summary for all three displays set to 100% scaling.
Resolume can see all three screens in the options but then miss identifies the screens when outputting. I think this then renders 1 display unusable. Resolume still only able to identify 2 displays and miss-numbers them.
EDIT - Changed the HDMI input to match the setup in my original post and also just noticed, when using identify displays, Display 2 is being shown faintly behind display 3.
So same hardware setup now giving different display outputs to previous test - but also 1 display identified twice..
RichVisuals
Is this an issue with my hardware, or is it resolvable?
RichVisuals wrote:When selecting advanced output:I can get it to output only by selecting the same screens (1 and 3) even though display 1 still shows as the primary monitor (3840x2160) the output is being sent at (3810x2160) to the (1680x1050)
Resolume starts drawing the outputs at the top left corners of the displays found.
1680x1050 seems to be an odd resolution.
So how does windows see these displays and how does Resolume report them?
Yeah it's weird but you find that on some monitors that are 16:10 but don't have enough pixels to be 1920x1200.
RichVisuals
Resolume screenshot above shows how the menu identifies the displays, windows matches this information.
Thanks for the reply, sorry for the delay in my response Zoltan.
RichVisuals wrote:Resolume screenshot above shows how the menu identifies the displays, windows matches this information.
sent you a PM.
