has there been some change to how mixer effects are handled? As I remember from Resolume 3, I could make custom mixers by creating an effect with 2 input textures and a blend parameter. Have a look at the ColorWrap mixer I made as an example: https://app.assembla.com/spaces/ffgl/su ... rWrapMixer
Now, in R3, this showed up in the blend modes drop-down along with the other mixers. However, I've just now recompiled it and added it to the Resolume 6 vfx directory, but it does not appear in the drop-down (nor anywhere else I can find). What to do? I would like to develop a new kind of blend for Resolume, but I can not get my mixers to show in the R6 interface.
FFGL Mixers in Resolume 6
Re: FFGL Mixers in Resolume 6
It's probably because you compiled your plugin for 32 bits applications. You need to build it for 64 bits for it to work.
Check out our ffgl respository on github, we've made some changes to make sure you can build 64 bits ffgl plugins.
https://github.com/resolume/ffgl
Ok, well I forked your repository on Github and am now trying to add my ColorWrap project to it. I added the Visual Studio project and the source files to the solution, as you can see at https://github.com/matiasw/ffgl , but when compiling, I get the error "Error LNK2001 unresolved external symbol plugMain FFGLColorWrapMixer C:\work\code\resolume ffgl\build\windows\FFGLPlugins.def 1". Why? All the other projects build fine, and I do have FFGL.h included, plugMain being defined in FFGL.cpp.
How do I get Visual Studio to resolve plugMain correctly for this new project?
I fixed this problem by creating a new project for the mixer. It now works in Resolume 6.
Expect a couple of new blends from me in a few days!
Ok, I'm trying to create a mixer where I render the textures on individual quads. However, I can't quite seem to get it to work: only one source texture is shown.
Here is the source:
https://github.com/matiasw/ffgl/tree/ma ... s/FFGLDrip
If anyone has any insight, please let me know!
Here is the source:
I think you've switched up your tex and vert coordinates here:
Code: Select all
//upper right
glTexCoord2f(1.0f, 1.0f+2.0-2.0*m_blend);
glVertex2i(1, 1);Re: FFGL Mixers in Resolume 6
Oops!
Yes, that's right, but the main problem still remains. Even when I altered the code to draw the two textured quads side by side, like this:
, I only get one full-screen quad. It seems like the blend is not processed at all.
In fact, I even added a constant-color fullscreen quad as the last item drawn, like so:
and it's not displayed! If I solo the layer with this blend mode enabled, I get a black screen even with opacity at 100%.
What could be wrong, here?
Code: Select all
//source A
glActiveTexture(GL_TEXTURE0);
glBindTexture(GL_TEXTURE_2D, TextureA.Handle);
glBegin(GL_QUADS);
//lower left
glTexCoord2f(0, 0);
glVertex2i(-1, -1);
//upper left
glTexCoord2f(0, 1.0f);
glVertex2i(-1,1);
//upper right
glTexCoord2f(1.0f, 1.0f);
glVertex2i(0,1);
//lower right
glTexCoord2f(1.0f, 0);
glVertex2i(0, -1);
glEnd();
//source B
glActiveTexture(GL_TEXTURE1);
glBindTexture(GL_TEXTURE_2D, TextureB.Handle);
glBegin(GL_QUADS);
//lower left
glTexCoord2f(0, 0);
glVertex2i(0, -1+2.0-2.0*m_blend);
//upper left
glVertex2i(0, 1+2.0-2.0*m_blend);
//upper right
glVertex2i(1, 1 + 2.0 - 2.0*m_blend);
//lower right
glVertex2i(1, -1+2.0-2.0*m_blend);
glEnd();In fact, I even added a constant-color fullscreen quad as the last item drawn, like so:
Code: Select all
glBegin(GL_POLYGON);
glColor3f(1.0f, 0.0f, 0.0f);
glVertex2f(-1.0, -1.0); // Bottom Left Of The Texture and Quad
glVertex2f(1.0, -1.0); // Bottom Right Of The Texture and Quad
glVertex2f(1.0, 1.0); // Top Right Of The Texture and Quad
glVertex2f(-1.0, 1.0); // Top Left Of The Texture and Quad
glEnd();What could be wrong, here?
Ok, well I "fixed" it by creating a new project. The same source now works.
This is why I dislike working with Visual C++/Visual Studio/Windows. Always some phantom bug haunting me....
Well, I have the mixer done now, you can see it in the Github... but, there's one bug left to iron out: for some reason, the quad I'm rendering does not entirely fill the screen. I'm looking at the Gradients example from the Resolume Github repo, and the coordinates seem to be the same as what I'm using, so I don't really understand why this happens. Here's the code to draw the quad:
And here's what it looks like:
I don't do any special setup of the viewport, so I think this -1..1 quad should fill the screen, no?
Code: Select all
glBegin(GL_QUADS);
//lower left
glTexCoord2f(0, 0);
glVertex2i(-1, -1);
//upper left
glVertex2i(-1, 1);
//upper right
glVertex2i(1, 1);
//lower right
glVertex2i(1, -1);
glEnd();
The -1..1 quad fills the screen. If you clear to red, you'll see the whole viewport is black.
You're sampling from a 1920x1080 image on a (likely) 1920x1088 texture. You'll need to multiply your texture coordinates with the max texture coordinates. You can get those via GetMaxGLTexCoords.
