Timed trigger
Timed trigger
I'd love to have the ability to key in a time to delay a clip from I trigger using column triggers. Something similar to Beat Snap but with time.
edwin
Re: Timed trigger
Post by edwin »
Interesting question, for what purpose would you use this?
For now you could use a Clip with a 'Blank' source, and change it's duration to the time you desire.
Then change the autopilot setting of that Blank Clip to trigger the Clip you need.
Re: Timed trigger
I've been doing that for years (used to make a solid color with alpha only before the blank clips) but it clutters comps for no reason and makes the process more complicated as you need to create an extra column.
Having the ability to delay the trigger of a clip in a column would make theatrical compositions much easier.
Empyfree
Re: Timed trigger
Post by Empyfree »
Oaktown wrote:I'd love to have the ability to key in a time to delay a clip from I trigger using column triggers. Something similar to Beat Snap but with time.
+one bazillion
PERCYJOSEPH
Re: Timed trigger
Post by PERCYJOSEPH »
+1 on this.
