Delay for slices
Electroguepard
Delay for slices
Post by Electroguepard »
In the same way that we can add a delay, small one, for diferent displays, would be amazing to add delays (seconds), to the slices.
Means that if you have a mapping with different slices with different delays you would be able to create animations easily with a single loop video.
If you map a robot face for example, video would start on the eyes, later on lips, later on eyebrows... Would be easy to bring dinamism to the mapping.
Re: Delay for slices
Kadete
Post by Kadete »
It looks so fluid!
I tryed to test something like this before a event using a layer with delay RGB effect over 10 slices but it breaks my fps to 10fps, 2seg before stabilizing.
This new delay param it will be in the next release?
We're working on a lot of options for slices. We have the basic 80% working. Now we need to break our balls over the remaining 20%. The agonizing 20% where you need to turn the test setup into a usable feature with understandable parameters that let you do the things you want in an easy way.
Electroguepard
Yes exactly!!! :lol:
If you are doing that implementations I guess that wil be possible also to group layers inside bins?
Thaaaaaanks!!!
mungle
Post by mungle »
Hello! News about that?
I'm looking for a delay options for slides... I have an NDI output and I have to synchronise it with the main arena output so I need a small delay for the direct output of my arena computer.
Thank you!
mungle wrote: Tue Aug 20, 2019 13:42 Hello! News about that?
Thank you!
https://resolume.com/support/en/screens#adjusting-delay
mungle
Post by mungle »
Hello!
Thank you for your quick answer. There is no option for NDI Output...
mungle wrote: Tue Aug 20, 2019 16:06 Hello!
Which Resolume version are you using?
Do you need NDI or do you need Output delay?
mungle
Post by mungle »
Hello! I have the last version.
In "Advanced Output" I create a screen with NDI as Device (instead a normal screen/videoprojector). This NDI output must be delayed. If I plug a normal screen I'm able to see the "delay" option, with Virtual Output/NDI/Syphon-Spout I'm not.
