Comp not transferring from Windows to Mac - 6.0.7
drewchrist87
Post by drewchrist87 »
Just installed the latest version of R6 on my MacBook Pro. I'm trying to open up the saved composition from my Windows laptop to my Mac but the comp doesn't change at all.
Re: Comp not transferring from Windows to Mac - 6.0.7
You should be able to use Media Manager to Reconnect your files.
Have you also copied the media files to your other machine?
satsi
Post by satsi »
I have this same problem. Built a comp on Mac High Sierra Arena 6.0.5, trying to relocate media on Win 10 Arena 6.0.6. All the media files are in place on both systems. Even if I just try to relocate one file by navigating to it,it won't replace it.
satsi wrote:I have this same problem. Built a comp on Mac High Sierra Arena 6.0.5, trying to relocate media on Win 10 Arena 6.0.6. All the media files are in place on both systems. Even if I just try to relocate one file by navigating to it,it won't replace it.
Try updating to 6.0.7.
satsi
Post by satsi »
I can't. There's a bug that I have yet to test to see if fixed in 6.0.8. The VLC NDI plugin stopped working in 6.0.7.
satsi
Post by satsi »
Well good news, 6.0.8 appears to have fixed the VLC issue. Thanks, guys! I'll give it a go and see if it fixes this mac to windoze thing. Stand by...
satsi
Post by satsi »
Success. It took me three tries to get all of the clips reconnected, but it did it. Thanks, again! This is very helpful on both fronts.
