We usually just run a 3 TV wide display at 3840x720 for an entrance arch. For some reason we're unable to display content natively at 5760x1080 with them.
Anyways, that's really the only thing we use them for. How can I get the most bang for the buck we've already paid for with the FX4s?
We have 3 Datapath FX4, hundreds of panels of LED wall. How can I use the FX4's to get the most out of them?
drewchrist87
Re: We have 3 Datapath FX4, hundreds of panels of LED wall. How can I use the FX4's to get the most out of them?
You’re missing a lot of detail here that would help anybody to help you!
How many LED panels have you got?
how big are they?
What pitch are they?
What computer rig do you have?
With what graphics card inside?
What arrangements of panels would you like?
How far is it from your computer to your processors!
What’s the maximum resolution supported by your processors?
Are your processors also scalers?
Oaktown is the de-facto Datapath expert on the forum, quick searches throw up quite a few posts where he explains various methods of setting them up to gain maximum pixels.
how big are they?
