Feedback source as an effect
Nackgi
Post by Nackgi »
I love the feedback source and playing with it, but it frustrates me a bit because it uses the whole composition as it's input.
Is there any way to somehow use the feedback more like an effect so it affects only one clip, layer or group instead of the whole composition so I could for example make an infinitely repeating background for a centerpiece clip which would not be included in the feedback?
Re: Feedback source as an effect
How about the Trails effect?
Nackgi
Post by Nackgi »
Zoltán wrote: Mon May 07, 2018 08:55 How about the Trails effect?
Trails can't do the kind of stuff I do with feedback.
Why is the feedback source plugin to begin with? It needs an input to generate anything.
Nackgi wrote: Sat Jun 09, 2018 18:04 Why is the feedback source plugin to begin with? It needs an input to generate anything.
I don't really understand the question.
The video router source can take layer textures as input, perhaps that would work for you.
edwin
Post by edwin »
I think what 'Nackgi' wants is a Feedback effect per Clip/Layer/Composition. Right now the Feedback effect always takes the content of the previous render pass of the Composition. You can't create Feedback local to a Clip a.t.m.
Sadler
Post by Sadler »
https://www.bigfug.com/software/freeframe/
Alex May's feedback plugin is great though not exactly the same but it does work in Res 6 on a per clip basis. It has a lot more options than the built-in source effect too.
Nackgi
Post by Nackgi »
Zoltán wrote: Mon Jun 11, 2018 13:23
I mean that feedback source doesn't do anything by itself. It always needs some input to generate graphics. So in my mind it would be more appropriate as an effect.
Nackgi
Post by Nackgi »
Sadler wrote: Wed Jun 13, 2018 20:10 https://www.bigfug.com/software/freeframe/
I'll have to try that out. Thanks for the tip.
