Hello to All,
I bought a Logitech Quick Cam for live video streams inside Resolume, but the quality is very poor.
What Cam has better resolution and maybe an auto focus?
I would like to use my Sony Analog Cam, but the capture driver of my Radeon 8500DV does not work with Resolume (see Msg before...)
Who can help me?
Bye, Eric
						best web cam for live video stream
				Jim_
				unj_
dont know if its the same as the asus gf3 dulex but you might need to have a seperate capture card rarther then use the agp one, even a cheep win tv will work, but as far as i can figer uninstall microsoft wdm drivers first and then instal any outher perticular wdm drivers spercific to your cheap capture card, dont know if it helps
you dont need to go for digi, if you carnt aford it, even digi8 works well within resolume
