free frame effects on clips
VJzoo
Post by VJzoo »
Im having some probs with free frame effects when they are on a clip.
If I apply a free frame to an effect layer (on the left hand side of the screen), the effects run fast and smooth but when i put the effect on a clip and play it the effect is very different, sometimes plays slowly.
P4 3ghz hyperthread, 1gig ram, winxp.
[Edited on 23-5-2005 by bunniboi]
can you give an example of what freeframe effect you are using?
VJzoo
Post by VJzoo »
i noticed it when i was useing chromeium and i tryed a few others as well with the same kind of result.
when i get home ill try all my free frams and report back ;)
VJzoo
Post by VJzoo »
i think ive got it,
when i save the parameter state on a clip it changes it for all the clips but it doesn't save the parameter to the global effect.
hope that makes sense ;)
