Resolume 6.0.9 & Adobe DXV Plugins Released
We keep them doggies rollin' with another Resolume release, version 6.0.9.
In April, Adobe stopped supporting Quicktime codecs in their software so it became impossible to render Quicktime files with the DXV codec across the entire Adobe family. We grabbed that bull by the horns and created Adobe exporter (and importer) plugins for DXV. This means you can now render to DXV straight from After Effects, Premiere Pro and Media Encoder.
Resolume 6.0.9 has over a dozen bug fixes and a couple of small but sexy new features. You can now create presets for colour palettes. On top of that, you can see some mighty fine lookin' previews in the popup for both the envelope and these new colour palette presets. Yihaw.
Now move 'em out head 'em up get 'em up & download.
New
#11169 Envelope Preset Preview
#11167 Envelope keyframe multi-select
#10870 Color Palette Presets
#11134 Hold shift to constrain envelope keyframe along vertical and horizontal axes
#11006 Select next/previous slice with Tab key
#11010 Add 'Show in File Browser' to Clip and Track Menu
#11324 Add Alley 1.0.1 to Avenue & Arena Installers
#11325 Add Adobe Importer & Exporters to Avenue & Arena Installers
Fixed
#10387 Appcrash changing decks with camera sources
#11335 Appcrash renaming Lumiverse and Screen
#10551 Appcrash clicking on Clip menu while deck still loading
#11278 Appcrash clicking to show param animation dropdown for a clip that's playing form another deck
#10829 Appcrash while recording in VCRUNTIME140!memcpy : 135
#11118 Appcrash dropping slice/fixture from slices panel to composition if slice is smaller than 1 px in a direction.
#11052 Possible Appcrash when using Spout (Arena!ra::SpoutVideoSource::render : 76)
#11185 Spout clip disappears from composition when you preview the spout clip's duplicate
#7588 HAP Q not yet fully implemented
#10972 SMPTE icon missing from clip
#11096 Command+A in shortcut editing can cause appcrash
#11032 Two nanoKONTROL2's / MIDI controllers connected no worky
#11164 OSC: Shaper source Shape1 and Shape2 type can only be set to Circle and Ring via OSC
#11161 OSC: clip transport can't be set to SMPTE, int 2-3 sets transport to BPM sync
#11141 OSC query does not return on the same address
#11021 OSC "Selected..." OSC output option disappears from list when you select a value - for layers and groups
#10997 OSC Group select messages are not sent
#10993 OSC Selected Group target doesn't follow selection
#10988 OSC /composition/direction int 2, and 3 not effective to set to paused and random, they set direction to forwards
pfelberg
Re: Resolume 6.0.9 & Adobe DXV Plugins Released
Post by pfelberg »
Wow!!! that's great news indeed!
Question... not to push on you guys...
Quicktime export on Vegas sometimes suxx as well. Any possibilities this plug-in would work as well with other products than Adobe?
craftycurate
Post by craftycurate »
Excellent. Thanks for your hard work gents. Will be trying out the DXV export soon.
craftycurate
Can once again import DXV MOV files into After Effects CC 2018 :D
timaroc
Post by timaroc »
I’ve updated and use the plugin to export video (by media encoder)
But the video does not export correctly,
the speed of sound is correct but the video is not correct.
And the problem is also happening in Compressor.
After I render the video, it’s correct played by Alley, but can not be played correct in Arena.
Is there any solution or ho can I do?
RickW
Post by RickW »
Can we get updated instructions on how to export with Adobe Media Encoder? I'm still not seeing DXV3 as an option after the update.
Can you get in touch with us directly? We'd like to see what the problem could be.
These plugins will work on Adobe After Effects, Media Encoder and Premiere only.
Right here fam: https://resolume.com/support/en/renderi ... v-encoding
RickW
Post by RickW »
Still no joy. DXV3 doesn't appear to be an option. See attached screenshot.
Can you also get in touch directly please?
Alchimist
Post by Alchimist »
I was holding my breath, and now, fresh air!
THAAAAAAAANNNNNKKKKKSSSSS!!!
