I'm new at LED, and needs help.
ultrafangs
Post by ultrafangs »
I'm starting to use LED strip to be controlled using Resolume, and I need advice about any hardware I need to use. I found a cheap PX24500 decoder with RJ45 port in a local marketplace, can I use it direct to Resolume using RJ45 cable?
Empyfree
Re: I'm new at LED, and needs help.
Post by Empyfree »
No, you’ll need an Artnet interface first.
Although they’d using RJ45’s the signal used is DMX rather than Artnet.
