request, i think? Rename Slice Transforms
djrummer
Post by djrummer »
Is there a way to name effects? specifically Slice transforms? I know I can map to a midi controller, but, would love to visually see it too.
any work arounds you all can recommend?
Re: request, i think? Rename Slice Transforms
Could you do me a favour and walk me through *why* you would like to do this? When you explain how this would improve your performance, it becomes a lot easier for us to implement it.
edwin
Post by edwin »
I think 'djrummer' means that he want to rename an effect which is applied to a Clip, Layer etc.
Sometimes when you have a couple of the same effects applied to a Clip it's hard to see in a glance which one does what. So renaming it can be quite useful.
AdevProjects
Post by AdevProjects »
Perhaps as an editable field to the right of the effect name, otherwise you wouldnt be able to tell what effect it actually was. eg. [Transform] - [editable name]
djrummer
Post by djrummer »
Sorry about the delay.
Yes. I want to use these effects the same way I would in an audio DAW.
I know I have 'rainbow hue/rotate'. or "blue green".
Instead of having the name of the effect -being able to right click it so I can visually see the name of the effect happening would be helpful.
Where as most people would probably automate the effect, I would rather create a 2nd instance and have them both as options.
but im new here.
Created a ticket for the features bucket ;)
I just want to leave a...
+1
...here, I think this could be very handy.
