Easy way to set MIDI mapping to composition
applehead
Post by applehead »
Hi All,
Is there an option in version 6 to specify MIDI mapping to individual composition setups?
Seems like when I do my mapping ,even if I make a new composition , the old MIDI mapping is still there.
In version 5 there was an option where it was possibly yo do this.
Thanks,
George
Re: Easy way to set MIDI mapping to composition
Resolume 6 will load the Shortcut presets that were active when you last saved your composition.
If you create a new composition, the last opened presets will still be active.
