Capture device no longer working in Res 6
machfox
Post by machfox »
Hi -
I have a Startech USB3 capture device.
It shows up in the sources but when I drag source into res 6 there is nothing.
It shows up in its own device software...just not in resolume anymore
It worked in res 4.
I am on res 6 win10 system
i7 6700HQ 2.6ghz / 16gb RAM
this is the capture device that no longer shows up -
https://www.startech.com/AV/Converters/ ... ~USB3HDCAP
any ideas I can try?
thank you
Re: Capture device no longer working in Res 6
Could you send us the Resolume log file via the feedback tab in preferences after trying to load the capture source?
pit_stolkysbit
Post by pit_stolkysbit »
is the problem solved ??
and what exact startech device you use ??
tnx
