Yaaaas queen! Finally! Alley 2.0.0 can now convert your video files to DXV.
We've made it ridiculously easy so your files are off blazing in two clicks, using super fast super multi-threaded super power. Of course, you can also fine tune your blend with presets and power user tricks. Check out the workflow and all the options in this Alley support article. Alley will always be free, so make sure it's part of your swiss army toolkit.
16 Bit DMX Input
You can now assign a DMX shortcut as 16 bit. Resolume will then automatically use the selected channel for coarse and the following channel for fine. Lampies will understand all the words in that sentence. Thanks Maarten!
Way Faster Adobe DXV Exporters
While we were working on Alley, we gave the Adobe DXV exporters a speed boost as well by making them multi-threaded. The more cores you have in your CPU the faster it will be.
Gl!tchy Tǝxt No More
We squashed the glitched out characters in the Text Animator and Text Block for good this time. No more weird looking text. Although the glitchy look was kind of awesome.
Grey Output Flash on Startup?
We all love a good flashy flashy, but thanks to the logs sent in by Brandon Little, Ozaer Faroqui and Thomy Hoefer, Resolume keeps a low profile during startup again and does not flash a grey frame in the output anymore.
Transformers
Pasting effects would result in an extra Transform effect that couldn't be removed. Now I have loved Transformers since I was a little babbie in the eighties. I even kept loving them when Michael Bay took them and CGI'd them to death. But this many Transformers was a bit much even for me.
l10n
The interface, onscreen help and manual are now disponible en Español, in Deutsch verfügbar and 有中文.
Download
Checkout the full fix list below, and just grab yourself a dime bag of that dank download.
Update! Thu 8 Nov, Hotfix List
#11972 Group Parameter Animation Menu does not open
#11949 Composition dashboard doesn't load stored names
#11954 Media Manager not working after save on new composition
#11969 Avenue footage installer creates wrong folder for registration file, then fails to register on OSX
#11960 Clipgrid scrollbars are not disappearing on resize, breaks vertical scrolling
Thu 1 Nov, Fix List
8458 play to end and hold' with 'continue from last pos' seeks to different frame on clip relaunch
9416 reveal effect moves original texture slices when set to centre scaling
9618 Text Atlas corrupt / text glitch
9776 MM: "Locate All.." doesn't work on Mac with MM comp that comes from Windows
10648 Monitor panel can lose title and settings icon
10841 DMX clip, column launch relaunches clip constantly above the launch threshold value when channel is changing
11111 Recording has wrong frame rate set when recording Audio + Video
11250 having many decks slows down composition load time considerably on OS X.
11254 DXV AV clip can flash clip's first frame when set to play to end and pause
11296 SMPTE Clip offsets are based on 25 FPS on composition reload instead of actual SMPTE frame rate setting.
11331 Dropping a deck from compositions panel to your composition makes the compositions list jump to the top
11353 Double clicking on Source presets to preview makes midi controller flash
11414 File search bar clears constantly when you convert a file to a folder that is visible in files panel.
11423 Layer texture is stretched when layer opacity is 0, and layer size is different than composition size
11453 File preview breaks for files panel after contents of folder changed
11456 New fixture renames itself back in fixture editor when scrolled out of view
11529 Clip Transport shortcut selection broken if you have in, out, and playhead mapped
11537 DXV3 Adobe exporter sets video stream to 23 fps when you select 23.98 setting
11553 Renaming an envelope preset creates a duplicate preset file.
11565 Paste effects adds a non removable transform to destination clip
11607 Appcrash loading Atlas cache, when a png is missing in it.
11610 Distortion VST effect drive and tone not effective
11665 Accept playhead/ in /out position for Audio and AV clips in hh:mm:ss.ms format too, similarly to Video clip's hh:mm:ss.ff format
11668 Soloed layer in a bypassed group is not rendered to group texture.
11671 Adobe DXV plugin fails with AE CS5
11683 App crash in ra::Envelope::Data::read
11686 Appcrash removing duplicate layer in attached composition
11697 Clip In/ out points not updating any more when they have been moved together via Midi
11707 Prediction around loop point results in wrong frame
11717 Scrubbing with playhead in playing AV clip via midi CC makes clip show random frames
11744 paused Clip transport position is sometimes displaying frames, sometimes milliseconds randomly on launch
11746 Layer preview incorrect when inside a group
11747 Layer router size incorrect when layer taken from a group
11748 Layer # visible in Video Router Input dropdown
11759 Add translated PDF manuals to installers
11764 Precision for setting Playhead, In/out position via left-right arrows on dingetje got very low.
11769 Panel on top left, in the same row as LayersAndClips resizes on every restart
11779 Importing still images and 1 frame DXVs does not give uniform duration
11794 Keyboard arrows on selected envelope keyframes are mixed-up
11795 Keyboard arrow moves Envelope keyframe in huge increments
11817 Clips get stuck on loading again
11851 16 Bit DMX Input
11880 Display hotkeys don't work on mac any more
11881 Display hotkeys are missing in the Output menu since 6.0.10
11909 Output can flash white/grey when output is enabled
Resolume 6.1.1 & DXV Video Conversion with Alley 2.0
Re: Resolume 6.1.1 & DXV Video Conversion with Alley 2.0
THANK YOU RESOLUME TEAM!!!!!!!
Do you like outlines? Easy Outliner on Juicebar -
rexaffects
Loving the new updates. Great job team.
I am having an issue with the update thought.... after the 6.1.1 update, my monitor output is blank when I try to trigger any clips. The preview monitor still works though. Any idea what went wrong?
Updating in the middle of the gig. Is this a mistake or just too much love?
