Cannot scroll after update to 6.1.1
Arvin
Post by Arvin »
After the update, the size of the material is fixed, can not be adjusted, only ten layers can be used up and down, can not be scrolled left and right!
Re: Cannot scroll after update to 6.1.1
Mac or PC?
Arvin
Post by Arvin »
On the Win10 system of the PC, this makes me very annoyed. I use the mouse to drag the progress bar, and accidentally move the dial to the sequential position!
I just tried on mac and Joris on windows but we can not reproduce this. Can you post a screenshot or video? Do you use a specific interface layout preset?
Arvin
Post by Arvin »
Arvin
Post by Arvin »
I recorded a problem video, which is about the mouse wheel. Before I can adjust to the maximum use of the mouse wheel, I can't adjust it to the maximum now, only up and down!
If I understand correctly, you have more layers than will fit in your layout without having a vertical scrollbar. This in turn means that the scrollwheel on your mouse no longer scrolls left/right, but up/down. And this happened after the update and now you are very angry.
If that's the case, maybe holding down shift to scroll horizontally is an option for you?
Could you zip and send us your Documents/Resolume Arena 6 folder?
You can send it to mail@resolume.com, mentioning this thread.
Edit: Could you try hiding the taskbar and making Resolume full screen?
Serg
Post by Serg »
Have same problem with 3 layers on PC and MAC. Can't scrool clips by mouse wheel.
VJsynC
Post by VJsynC »
oh, by the way... forgot to mention.... with Resolume in full screen it's the same... the problem persists!
